EFC offers solution for attaching carbon fiber & composite panels
By Michelle Froese | October 2, 2019
EFC International’s new BCT rivet nut is a best-practice, light-weighting solution for attaching carbon fiber and composite panels for the automotive industry. The rivet nuts are manufactured by BBA with bulge control technology (BCT). BCT rivet nuts are ultra-high strength and engineered to prevent cracking or delamination of carbon fiber panels.
BCT Rivet Nuts offer BCT or bulge control technology, a patented solution to control where a bulge forms when rivet nuts are installed.
The patented design enables an engineered yield point on the body of the rivet nut, ensuring the bulge formation always begins beyond the panel and is drawn back on the panel. BCT rivet nuts can be placed near the edge of the panel without concern of inducing a crack in the panel.
The installation process of BCT rivet nuts can be fully process-monitored and controlled. They can also be installed into areas that offer limited rear side clearance. An M6 rivet nut needs only 8mm of rear side clearance prior to installation and only 5mm after installation.
This is ideal for use in thinner version of sandwich (composite) materials, avoiding the need for a through hole. The bulge of the BCT product is strong enough to form by pushing away any material in the sandwich material.
Additionally, by producing BCT rivet nuts from aluminum for use in aluminum and magnesium, the weight is reduced dramatically.
EFC International
www.efc-intl.com
Tagged With: efcinternational
