Piab, a supplier of industrial vacuum technology, offers its patented COAX® technology in a new small sized ejector called piPUMP™ MICRO. COAX® is the most energy efficient ejector technology based on a multi-stage concept for creating vacuum with compressed air.
piPUMP™ MICRO is truly easy-to-buy and easy-to-mount and use. A handy configurator tool on Piab’s website, www.piab.com, allows the user to select the vacuum characteristics along with a few options for filtration and connections.
The piPUMP™ can be used for small centralized systems but perhaps even more suitable for semi-decentralized systems, i.e., a few units creating vacuum supporting a few small cups each. Thanks to very low weight and small dimension it can also be used as a fully decentralized ejector on a Delta robot for example.
The small footprint of the unit provides flexibility in mounting and use. Installation is a breeze with push-in connections and a common feed for compressed air, regardless of the number of units chosen. The central exhaust allows the exhaust to be drawn away in clean room environments
Because COAX® Cartridges are up to twice as fast as other cartridges and provide three times more flow than a conventional ejector with the same air consumption; the piPUMP™ MICRO is able to provide a high performance even at low or fluctuating feed pressures (14-87 psi). Additionally, piPUMP™ MICRO vacuum units begin producing vacuum immediately when the pressure valve is turned on, making maximum use of the compressed air and consuming significantly less energy than traditional vacuum pumps.
Piab
www.piab.com
Filed Under: Hose • wraps + sleeves, Pneumatic equipment + components
