B&R and Maplesoft announced a partnership that will bring together products from both companies to save time, effort and cost for hardware-in-the-loop simulations.
Being able to design an adequate machine or system model plays an important role in simulation-based development. At the same time, mapping out all the dynamic characteristics of a machine can take a lot of time. “Tools for physical modeling such as MapleSim™ from Maplesoft™ provide optimal support and reduce the amount of time and work considerably,” said Philipp Wallner, Global Technology Manager at B&R.
The open architecture of Automation Studio – B&R’s programming and development software – ensures that physical models designed in MapleSim™ can be transferred to B&R controller hardware in just a few easy steps. The result is a hardware-in-the-loop simulation that emulates the machine’s behavior in real time, in a completely safe testing environment.
“Using MapleSim, Automation Studio users can very quickly develop high-fidelity models of the control plant, analyze the dynamics, and then generate highly optimized real-time code for the plant,” said Dr. Laurent Bernardin, Vice President, Research and Development, Maplesoft. “By adding an easy-to-use and cost-effective physical modeling phase to the automation workflow, engineers will be able to increase virtual testing prior to hardware commitments. A definite way to reduce costly design errors.”
The close cooperation between the two companies ensures optimal integration in Automation Studio, a clear and comprehensive workflow, and long-term support for the user.
B&R Industrial Automation Corp.
www.br-automation.com
Filed Under: Factory automation, Software
