Efficient multipurpose parallel and angular grippers
By Megan Hollis | November 12, 2014
Bimba Manufacturing Company, an industry- leading provider of pneumatic, hydraulic, and electric solutions, and its subsidiary Mead Fluid Dynamics (MFD), an innovative manufacturer of pneumatic components, today added extruded pneumatic parallel and angular grippers to its full line of MFD products.
Bimba Gripper Mounts1
The new parallel (Model MHFZ) and angular (Model MHFY) grippers feature robust, clean and compact extruded aluminum bodies for maximum mounting efficiency. A magnetic piston for position sensing is included on all models. The parallel grippers are available in double and single acting with seven bore sizes and two finger types, offering a range of gripping force output to 144 lbf. The angular grippers are available in double and single acting with six bore sizes, offering a range of torque output to 65 lbs.  Both are interchangeable with popular international brands.
The gripper line is particularly suited to a broad range of general automation processes, including pick & place, material transfer, clamping, camming and indexing.
Bimba
www.bimba.com
Pneumatic Tips
Filed Under: Hydraulic equipment + components, Pneumatic equipment + components, Robotics • robotic grippers • end effectors
Tagged With: bimba
