Elastomer couplings with higher torque handling capacity
By Leslie Langnau | May 5, 2010
The growing popularity of curved jaw (elastomer) style couplings for precision applications has driven the need for couplings that handle more than the traditional torque capacity of 2,150 Nm up to a maximum torque of 25,000 Nm.
Available with split clamping collars or keyway and set screw connections, the three new body sizes allow for backlash free, vibration damping power transmission, paired with strong torque density. Dual flexture and jack shaft versions are also available for spanning longer distances and compensating for larger misalignments. Unlike the pre-existing range of R+W elastomer couplings, which use a single spider element between the new hubs, the new larger sizes will use individual vibration damping compensation elements to fit between each mating set of coupling teeth. These couplings are available in English and metric bore diameters up to 170 mm.
R+W America
www.rw-america.com
Filed Under: Torque Limiters, Flexible, Elastomer, NEWS • PROFILES • EDITORIALS, Couplings
Tagged With: R+W America, Flexible, Torque Overload, couplings, elastomer
