Electrical Engineers Take Major Step Toward Photonic Circuits
By University of Alberta | August 20, 2014
Team invents non-metallic metamaterial that enables them to ‘compress’ and contain light
Edmonton—The invention of fiber optics revolutionized the way we share information, allowing us to transmit data at volumes and speeds we’d only previously dreamed of.
Now, electrical engineering researchers at the University of Alberta in Edmonton, Alberta, Canada are breaking another barrier, designing nano-optical cables small enough to replace the copper wiring on computer chips.
This could result in radical increases in computing speeds and reduced energy use by electronic devices.
“We’re already transmitting data from continent to continent using fibre optics, but the killer application is using this inside chips for interconnects—that is the Holy Grail,” says Zubin Jacob, an electrical engineering professor leading the research. “What we’ve done is come up with a fundamentally new way of confining light to the nano scale.”
At present, the diameter of fiber optic cables is limited to about 1/1000th of a millimetre. Cables designed by graduate student Saman Jahani and Jacob are 10 times smaller—small enough to replace copper wiring still used on computer chips. (Put into perspective, a dime is about 1 mm thick.)
Jahani and Jacob have invented a new, non-metallic metamaterial that enables them to “compress” and contain light waves in smaller cables without creating heat, slowing the signal or losing data. Their findings will be published in Optica (Aug. 20), The Optical Society’s (OSA) new high-impact photonics journal. The article is available online.
For more information, visit www.ualberta.ca.
