Manufactured using a tightly controlled, 5-step electroforming process that begins with a solid aluminum stock that is machined to an internal geometry to create a mandrel. A layer of metal is then electrodeposited to a precise thickness onto the mandrel, the ends are trimmed, and the mandrel is chemically dissolved, leaving behind the finished part.
Electroformed bellows are the optimum solution for critical applications that demand complex geometries, seamless construction, leak tightness, and miniature sizes. These precision engineered components deliver performance, durability, repeatability, and dependability that other alternatives cannot.
Servometer uses a signature Cobalt-Nickel alloy, FlexNickel, that is able to meet the temperature capability and structural rigidity of metal yet retain the flexibility and weight of plastic components. FlexNickel can be used with other surface finishes, such as copper, gold, & silver.
MW Industries
www.mw-ind.com
Filed Under: Coupling Tips
