The PSW2000 is a high accuracy electronic pressure switch with a digital display. The switch is available with either 2 solid state relays or 1 solid state relay plus an analog output.
SS wetted parts with a FKM (fluorelastomer) seal plus an IP65 enclosure and UL approved rating allow this rugged switch to be used in most industrial environments. Measurement ranges are available in both gage and absolute pressure references from 15 psia to 9000 psig.
Filed Under: Electronics • electrical, Switches, Test + measurement • test equipment
