Eliminate system vibration
By Frank Tobe | May 19, 2016
mikiThese CPU pin-type couplings effectively dampen system vibration, especially on packaging systems.
Designed using a simple pin and bushing connection that minimizes vibration, these couplings handle angular misalignment of 4° and parallel misalignment of 0.5 mm. The design maintains zero backlash for smooth system operation. Also, the couplings’ aluminum construction makes for a lightweight yet strong coupling body capable of absorbing and dissipating heat from adjacent sources in a system.
Clamp style hubs slip easily onto two connecting shafts with the coupling locked into position with recessed tightening screws.
The coupling handles system speeds up to 4,000 rpm, is RoHS compliant, and available in three models in bore sizes ranging from 6.00 to 22 mm. Transmittable torque for these sizes range from 2.2 to 25 Nm.
Miki Pulley
www.mikipulley-us.com
Filed Under: Couplings
Tagged With: mikipulley
