A new Series of 17 elliptic leaf spring antivibration mounts from Advanced Antivibration Components – AAC are impervious to corrosion and will operate efficiently under a wide range of temperature, making the units well-suited for ship board or mobike applications. Their basic design employs two or more high range of tensile stainless steel “U” formed leaves, situated at each end, forming an elliptical shape when joined together in the center portion with face plates. The spaces between the “U” formed leaves are filled with a specially developed polymer or stainless steel mesh. These mounts are featured at the AAC eStore where you can order online, request a quote, download CAD models, check stock plus view catalog and technical pages.
The leaves in these mounts, identified as V10Z70-… Series, are made of 304 stainless steel and the washers are made of nylon and stainless steel. The damping compound is made of polymer for the “X” mounts and stainless steel mesh for the “XM” mounts. They have a wide range of applications which include their use in: military applications, air compressors, engine suspension, shipboard electronics & equipment, radar communication equipment, electronic control equipment, bomb and other lifting gear, mobile vehicles, pumps, blowers and fans.
www.vibrationmounts.com/newproducts/LeafSpring.htm
Filed Under: Mechanical, Shocks + vibration control • gas springs
