The EMC shield clamps have a versatile portfolio; they are used for the safe dissipation of high-frequency interference, and are enhanced by the SKZ shield version. The new SKZ offers an additional integrated strain relief. The strain relief is accomplished via the cable outer sheath and it also protects the cable shield, it is mechanically designed for tensile forces. Strain relief from the cable shield can cause damage, even to the individual cores.
icotek’s new shield terminal can be mounted on DIN rails, 10 x 3 bus bars, C-rails and with one screw on mounting plates in a very user-friendly way. The clamping ranges are between 3-8 mm and 4-13.5 mm.
icotek offers numerous other space-saving and very easy to install EMC solutions, such as the MSKL series with large clamping ranges of 3-12 mm and 8-18 mm, which can be mounted directly on DIN rail, bus bar and C-rail.
icotek Corp.
www.icotek.com
Filed Under: TECHNOLOGIES + PRODUCTS, Flanges • supports • mounts • brackets
