Emerson Bearing of Boston, a supplier of bearings and related products catering to Original Equipment Manufacturers and Maintenance, Repair and Operations markets around the world, has expanded their Super Precision bearing line and offers a complimentary eBook entitled The Art of Precision Bearings: Handling, Mounting, and Technical Guide to Precision Bearings.
High-speed turbochargers, balancing machines and other equipment that needs to operate at radial speeds of 400,000 RPM use higher Super Precision ball bearings. Emerson’s expansive Super Precision bearing line now includes Barden, GMN, Nachi and NTN brands.
Machinery that uses Super Precision bearings
Super Precision bearings are suitable for applications that demand a high degree of running accuracy, have high system rigidity, need to extend speed capabilities and maintain low heat generation as well as minimize noise and vibration levels.
The optimized dimensional performance and operational capabilities provide a return on investment that exceeds that of standard bearings. Applications where precision bearings provide the greatest benefit include metal cutting and woodworking, super precision lathes, vacuum pumps used in industrial and sterile environments, high speed rolling mill machines, as well as printing, milling and balancing machinery.
Emerson Bearing
info.emersonbearing.com
The post Emerson Bearing Boston expands inventory appeared first on Bearing Tips.
Filed Under: Bearing Tips
