Emerson Network Power Expands ADN DIN Rail Power Supply Family
By Patrick Curran | December 22, 2009
Carlsbad, CA – Emerson Network Power announces the ADN-C series, a next-generation addition to its ADN DIN rail power supply family. The new ADN-C power supplies offer high density, efficiency, reliability and user-friendliness for a wide range of industrial applications including machine control, semiconductor fabrication, conveyor/material handling, process control, test and measurement equipment and vending/gaming machines.
ADN-C series power supplies are available in three models in power ratings of 120 W, 240 W, and 480 W (5 A, 10 A and 20 A respectively). All models offer an adjustable, nominal output voltage of 24 Vdc and accept a universal wide input voltage range of 85 to 264 Vac (90 to 375 Vdc) to support international operation.
Designed for convenient single or parallel operation when mounted on standard DIN rails, Emerson Network Power’s ADN-C series power supplies feature a new slim form factor (50 to 87 mm wide, depending on the model), allowing customers to increase the power density potential of a single rail. The power supplies offer a high typical operating efficiency of more than 90 percent and are also equipped with active Power Factor Correction (PFC) greater than 0.92.
To ensure high reliability, ADN-C series power supplies are comprehensively protected against continuous short-circuit and overload conditions. They have a high demonstrated mean time between failures (MTBF) of over 450,000 hours at 40 degrees Celsius. Furthermore, ADN-C series power supplies can flexibly accommodate a variety of environments, offering a wide operating temperature range of minus 10 to plus 60 degrees Celsius without derating.
The power supplies are also equipped with a number of features to simplify operation. PowerBoostTM overload capability enables Emerson Network Power’s ADN-C series to withstand high inrush loads, such as motors, relays, solenoids and dc-dc converters, which can cause ordinary power supplies to fold back or shutdown. A patented DIN rail mounting clip enables tool-free snap-on mounting specially designed for industrial environments. Other user-friendly features include three LEDs on the front of the case (input, output and alarm) for status monitoring, large accessible screw terminal connections and a single/parallel operation toggling switch for enhanced scalability.
ADN-C series power supplies are compliant with Restriction of Hazardous Substances (RoHS) directives and are approved for use in Class 1, Div 2 hazardous locations. They also meet standard requirements for voltage dip immunity in semiconductor fabrication equipment as well as a variety of international safety and performance standards, including UL and CE listings.
ADN-C series power supplies are backed by a five year limited warranty and are available to order now. For more information, visit http://www.powerconversion.com/products/websheet/416/ADN-C.
www.EmersonNetworkPower.com
Filed Under: Electronics • electrical, Power supplies
molex-premo-flex
