Emerson has introduced new heat-staking technology intended to give manufacturers greater design freedom by enabling them to join delicate and complex components to plastic moldings.
The Branson GPX platform provides greater design freedom by enabling high-quality joins and superior aesthetics in a range of challenging applications.
Using a unique pulse-staking technology that optimizes the heat staking process, the Branson GPX platform produces high-quality joins, superior product aesthetics, and energy savings in increasingly challenging applications.
Electronics, automotive, and medical device manufacturers must produce more creative designs to meet rapidly changing market demand.
This has led to an increase in challenging heat-staking applications involving parts with more complex 3D geometries, closely aligned features and fragile or heat-sensitive components — such as soldered components or sensors, and using a greater number of blended, glass-reinforced, chromed and metallicized plastics.
The Branson GPX platform uses PulseStaker technology to provide instantaneous heating and cooling, with adjustable cycle times for optimized, low energy heat staking. The process creates no particulates or burn marks, and enables more delicate and sensitive parts, such as those with embedded electronics, to be joined with consistently high-performance finishes.
“The automotive, electronics, and medical industries require more complex, delicate, and sensitive components to be joined to plastic moldings,” said Priyank Kishor, global product manager for Branson products at Emerson´s Automation Solutions business.
The advanced technology is suitable for all heat staking applications, including those with thermoplastic materials and metalized coated parts. A wide range of heat staking tip designs, which can be adapted to meet any stake welding requirement, and the ability to stake multiple points simultaneously provide manufacturers with greater design freedom.
“The unique heat staking process that the Branson GPX platform provides helps to meet this demand and offers manufacturers a broad range of benefits, such as superior product aesthetics and reduced energy use,” added Kishor.
You may also like:
Filed Under: Welding • soldering
