    • Subscribe!
Enable IP68/69k Operation Quickly
By Design World Staff | April 21, 2010
The G11 Module for AS-Interface specification 3.0 features 4in/4out, a multi function LED on each port, short circuit output protection and 4 Amp output current, all in an 85 mm diameter housing. Eight M12 input/output connections can be mounted in any orientation.
The symmetric sealing contours around the gold-plated piercing pins provide a precise fit to the AS-Interface cable. The only externally exposed materials are impact resistant and chemically inert PBT and stainless steel. The G11 family is compatible with AS-Interface POWER24 and can operate on 24 Vdc.
Pepperl+Fuchs
pepperl-fuchs.com
Filed Under: Networks • connectivity • fieldbuses
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
    • Subscribe!
