Mencom offers over-molded 12, 16, 17 and 19 pole M23 encoder connectors with straight or right angle heads. The connectors are all UL listed and designed to endure positive vibration for use with motor drives and moving assemblies. Plus, they provide IP67 rating for harsh industrial environments.
The cable jackets are available in ITC-ER PVC, shielded PUR and shielded TPE jacket, and they are offered in many standard off the shelf lengths. The mating receptacles are available with ½ in. NPT, Back mount, Panel Mount, Rear mount, M20 or M20-long (for thicker panels) mounting threads.
Along with being the only manufacture to offer M23 receptacles in ½ in. NPT shells, Mencom provides a wide variety of color codes to match your encoder application needs. The standard shell material is nickel plated brass, while the M20 is also available in stainless steel.
The post Encoder connectors offered in 1/2 in. NPT appeared first on Connector Tips.
Filed Under: Connectors (electrical) • crimp technologies, Connector Tips, MOTION CONTROL
