Hudson, MA – Anver Corporation announces a line of micro-miniature venturi vacuum pumps, suspensions, and vacuum cups for fast attach-and-release EOAT (end-of-arm-tooling) in automation systems.
Anver JV Series Venturi Vacuum Pumps, Suspensions, and cups are ideal for EOAT because they are lightweight and can be located close to the pick-up point to provide millisecond attach-and-release. Suitable for virtually all automation equipment, the pumps can be positioned close together, suspensions are offered in many sizes and fittings, and the suction cups come in a variety of materials including ESD-safe NomaStat™.
Designed for use in a wide range of small automation and handling processes, Anver JV Series Venturi Vacuum Pumps feature thermoplastic construction, weigh only 16 grams, measure 1” x 1.69”, and can achieve 24”Hg vacuum with either .050 or 0.74 SCFM flow rates, depending upon model. Suction cups for small robotic EOAT systems are offered in 3 to 8 mm O.D. sizes in 0.5 mm increments and are offered in flat or bellows styles.
Anver Corporation
www.anver.com
Filed Under: Factory automation, Automation components, Material handling • converting
