Engineered systems provide easily configurable, high-precision, multi-axis motion
By Miles Budimir | October 17, 2024
PI’s new X-417 Integrated Multi-Axis System (IMAS) provides machine builders and system integrators with a freely configurable solution, utilizing highly dynamic, precision XY linear stages as a base, with travel ranges from 4 to 16 in. (102 to 407 mm). The X-417’s modularity allows users to configure the system according to their application needs, including travel ranges, the number of axes required, and a choice of accessories. They receive a custom-tuned system, aligned and calibrated to their specified requirements.
multi-axis motion
X-417 systems are available in three performance classes, each including a suitable EtherCAT-based high-performance motion controller from PI. All systems, except for the entry-level performance class, are based on a linear motor-driven XY stage with a user-selected travel range and load capacity. The system is expandable with rotary and Z-stages, which can be mounted either on the XY stage or separately on the granite bridge or bracket. Users can also select base plates made of granite, brackets made of aluminum or granite, and additional accessories such as a base frame with integrated vibration isolation. The user-configured system will be delivered with suitable cables and appropriate cable management.
Applications include metrology, laser machining, ablation, and welding, galvo integration, ceramics and diamond cutting, test & inspection, and electronics manufacturing, among others.
For more information, visit www.pi-usa.us.
Tagged With: PI, physikinstrumente
Miles Budimir
