    • Subscribe!
Enhanced parallelism measurement accuracy with the XK10 alignment laser system
By Heather Hall | September 1, 2021
Global engineering technologies company Renishaw has released a new version of software for its XK10 alignment laser system which enables users to perform point-to-point parallelism measurements. This new functionality will also enable users to make precise adjustments to machine parallelism to a level that has previously been impossible using traditional measurement techniques.
The XK10 alignment laser system provides a fast, precise and efficient measurement tool for straightness, squareness, rotational parallelism, rail parallelism, flatness, and level, as well as assessing spindle direction and coaxiality of rotary machines. It is a powerful tool for diagnosing the source of errors following a rebuild or as part of regular maintenance.
Traditionally users achieved parallelism measurements by using a bridge plate and master rail, in combination with a dial gauge and level meter. This method is time-consuming and recording the measurements manually increases the probability of human error. Alternatively, the XK10 uses laser measurements to capture two points on each rail, allowing the angle between the two rails to be determined and recorded digitally.
“This latest release of software enables the XK10 to take measurements at multiple points along each rail,” said Andy Deacon, calibration product manager at Renishaw. “The benefit of an increased number of measurement points is that the straightness of each rail is also measured at the same time. Parallelism between the rails can then be determined by looking at the difference in straightness at each point, giving a more accurate picture than a measurement of the overall angle between rails.
“The XK10 is supplied with fixturing solutions to reduce set up time and can be used with the optional parallelism optic designed specifically for this application. Making measurements where no rails are present is significantly improved using the included magnetic reference mount to easily slide the detector along the edge of a casting,” said Deacon.
Renishaw’s calibration products, including the XL-80 laser interferometer, QC20-W ballbar and XM-60 multi-axis calibrator, are essential tools that enable users to gain a greater understanding of a machine’s capability. Regular maintenance checks of the condition of a machine, with powerful diagnosis of the source of any errors, minimizes the need for reactive maintenance and focus on valuable preventative work. CARTO software suite provides data capture, analysis and compensation applications, simplifying the process for monitoring and improving position performance.
For more information, visit Renishaw at upcoming shows, such as Eastec from Oct. 19-21 on booth 3151. Renishaw will also exhibit at The Quality Show from Oct. 26- 28 on booth 827 and at Westec from Nov. 16-18 on booth 815.
You may also like:
  • Nexa3D to to showcase its end-to-end 3D printing equipment at…
  • Blue industrial lasers make it easier to work with reflective…
  • Improving coordination between electrical and mechanical design of electronic products
  • 60-A Woodhead switch-rated connector system safely de-energizes machinery
  • America Makes announces OASIS Challenge winners
  • red tail
    LiDAR system optimized for small drones
Filed Under: Lasers
Tagged With: Renishaw, Renishaw Inc.
laser plastic welding
Plastics locked down and laser welded
AR550 high speed laser sensor from Acuity designed for vibration measurements and more
SendCutSend-basket-IMG_2080
How to design for laser cutting
New line of compact DPSS lasers and systems from Quantum Composers
    • Subscribe!
