EP21AN Two Part Adhesive System
By Design World Staff | February 18, 2009
HACKENSACK, NJ
‚– Master Bond Inc. has developed a new two part adhesive system called EP21AN with a thermal conductivity in excess of 22 (BTU‚•in/ft‚²‚•hr‚•‚°F). It is an outstanding electrical insulator with a dielectric strength of >400 volts/mil and a volume resistivity greater than 1013 ohm-cm. This easy to use adhesive has been formulated with a non-critical 1/1 mix ratio by weight or volume. It cures readily at ambient temperatures or more quickly at elevated temperatures.
Master Bond EP21AN features excellent adhesion to a wide range of substrates including metals, ceramics, glass and many plastics. Bonds exhibit outstanding dimensional stability and shrinkage upon cure is exceptionally low. Master Bond EP21AN is available in 1/2 pint, pint, quart, gallon and 5 gallon kits.
www.masterbond.com
Filed Under: Adhesives • epoxies, Materials • advanced
