    • On the Floor
  • Advertisers
    • PR Submissions
    • Eblast Submissions
EpoxySet Releases EO-98HT, Very High Temperature, Electrically Conductive Adhesive
By EpoxySet | April 17, 2017
EpoxySet Inc. recently introduced its EO-98HT, an electrically conductive epoxy for electrical circuits, LED attachment, die attach, and grounding applications. The EO-98HT is ideal for solder replacement or circuit/wire bonding where high conductivity and reliability are required. Being a silver-filled adhesive, it produces a very high thermal conductivity, a glass transition temperature of 136°C and is rated for continuous use up to 250°C, ideal for demanding, high temperature needs.
Key Features
  • Volume resistivity of approximately 10-4 ohm-cm
  • Glass transition temperature of 136°C and is rated for continuous use up to 250°C
  • 30-day work time at room temperature and can be stored frozen for up to a year. It can be cured at fast as five minutes at 150°C
  • One-part system
  • What DRC Reports Tell You and What They Don’t
  • Big growth in U.S. industrial automation
  • Siemens aims for 80 percent automation in German plant
  • Tech Toolbox: Machine design for food automation
  • Tech Toolbox: Machine design for packaging
    • On the Floor
  • Advertisers
    • PR Submissions
