Equipment Delivers Molded Rubber Products Faster and Less Expensively.
By Design World Staff | December 12, 2011
Robinson Rubber Products, a designer, developer and manufacturer of custom-molded rubber products, extruded rubber products and precision rollers, announces it is will add four rubber molding presses to the two it already has.
The six up-acting compression presses will have faster throughput, greater capacity and deliver more consistent parts. This means better molded rubber parts, faster for less money.
Bonding a rubber component to your part can also eliminate secondary operations and extra components, plus reduce weight and costs.
Rubber Molding Press
These presses have three advantages. One, they are large-scale presses so parts can be larger or they can hold additional cavities for greater production capability. Two, with compression clamping forces up to 700 tons, they have tremendous throughput. Three, they have vacuum chambers that drop around the mold. Encasing the mold and pulling a vacuum eliminates the defect potential from air entrapment. The vacuum chamber also creates a stable insulator. Keeping the temperature consistent in the mold during curing adds to a part’s consistency and reduces waste. Automated mold handling rigs on the presses speed up production and improve worker safety. Also, more sophisticated computer control and programs deliver complete repeatability.
“Providing sophisticated bonded assemblies of high quality is our specialty, with over 70% of our rubber being bonded to substrates,” says Jay Beck, President of Robinson Rubber. “This process delivers high performing components to our customers with virtually zero returns,” says Beck.
Substrate parts include but are not limited to chain pads, conveyor pads, diaphragm assemblies, electrical insulators, ground spool valves, impellers, inflatable butterfly valve seats, motor mounts, non-invasive medical devices, power drive assemblies, sanding disks, special wheels, valve assemblies, vibration isolators and vibration mounts.
www.robinsonrubber.com
Filed Under: Machine tools + subtractive manufacturing, Materials • advanced
