ERD Electric Rod-style Actuator from Tolomatic
By Miles Budimir | June 29, 2010
HAMEL, MN – Tolomatic’s new ERD electronic rod-style actuators are designed as an economical electric alternative to non-repairable pneumatic cylinders and provide design engineers with a new option for automating manual processes. Sleek and compact, ERD electric rod-style actuators deliver forces up to 75 pounds (334 N) at speeds up to 40 inches per second (1,016 mm/sec). ERD actuators are stroke configurable and ship within five days from order entry at the factory. The products are suitable for a wide variety of applications, including product change-overs, pick-and-place, sorting and diverting, heat-staking and more.
Tolomatic-ERD-electric-rod-style-actuator
The ERD electric rod-style actuator is available in body sizes that are equivalent to 5/8”, 1” and 1.5” bore non-repairable pneumatic cylinders. These three sizes are available in stroke lengths up to 8, 10 and 12 inches, respectively, and forces up to 20, 40 and 75 pounds. The three sizes, from small to large, accept NEMA 11, 17 or 23 frame stepper and servo motors. The acme lead screw is made of high-performance steel and is available in three lead sizes per size to optimize speed or force.
ERD products are round bodied, following the footprint of most pneumatic actuators in this performance class. The rear head of the actuator features an oversized main bearing to accommodate high thrust loads and provide long life. The main tube and thrust tube are made of stainless steel for high rigidity and corrosion resistance, while the metric-threaded nose mount accepts a jam nut that provides convenient mounting for many applications. Mounting options include a rear trunnion mount, foot mounts or a front flange mount.
The ERD actuators can accommodate six different sensing or switching choices: reed, solid state PNP (sourcing) or solid state NPN (sinking), normally open, flying leads or quick-disconnect. The switches are activated by a standard internal magnet located inside the thrust tube. Commonly used for end-of-stroke positioning, these switches allow clamp-on installation anywhere along the actuator tube. All switches are CE rated and are RoHS compliant for environmental compatibility.
Tolomatic
www.tolomatic.com
Filed Under: Actuators, Linear motion • slides, Motion control • motor controls
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
