ErgoWeld Compact Stud Weld Tool
By Design World Staff | September 17, 2008
Huntley, IL ‚— IMAGE Industries announces ErgoWeldTM.  The 3/8‚” compact drawn arc stud welding tool weighs less than two pounds, and can be used in the tightest weld areas. This ergonomically designed tool allows for more efficient welding with its ‚“fit-like-a-glove‚” comfort.
Precision engineered, stainless steel internal components are housed in a rugged body of high durability polymer plastic. This unit significantly increases productivity by reducing worker fatigue with its lightweight design. Its simplified operation allows for novice and experienced users alike to reap the benefits and also make quick and easy adjustments. It has been designed for quick setup, optimum performance, and compatibility with most arc stud welding power supplies.
The compact drawn arc stud weld tool is ideal for jobs where operator fatigue can play a significant factor in productivity. IMAGE‚’s inventive response to a recurring problem has proven to be a winner in the stud welding arena, with their new ErgoWeld compact stud weld tool.
www.imageindustries.com
