EtherCAT Multi-Fieldbus Interface (MFI) permits seamless integration with other platforms
By PR Editor | July 10, 2019
KEB America announced the availability of a new EtherCAT Multi-Fieldbus Interface (MFI) for its controllers. Using the MFI, customers will be able to easily connect KEB’s high performance multi-axis controller with an existing whole-machine PLC solution without abandoning existing fieldbus integrations. For example, users can choose to develop a machine accessory using KEB’s EtherCAT-based controllers and I/O modules and then connect it to an existing machine, using only one module.
KEB’s EtherCAT Multi-Fieldbus Interface (MFI) permits seamless integration with other platforms.
The MFI, a new addition to KEB’s EtherCAT I/O module series, is an EtherCAT slave device that provides a gateway connection to a second fieldbus interface. It is available as an EtherNet/IP adapter, a ProfiNet I/O device, and a Powerlink slave. The MFI interface allows the user to join two fieldbus networks and exchange up to 300 bytes of data (per scan) seamlessly between them. The module works with all of KEB’s modules including EtherCAT digital, analog, relay, counter, safety, and stepper motor control modules. It is DIN rail mountable and connects directly to KEB’s remote I/O EtherCAT backbone.
Programming time is kept to a minimum because it does not require platform specific programming of existing solutions. Users are able to develop motion solutions independent of the final user’s target platform and simply select the MFI that links the KEB EtherCAT control platform to the required PLC platform. The interface is CE and cUL compliant to ensure conformity to market specific regulations.
Machine builders will benefit from its low implementation cost, ease-of-use, flexibility, and performance. Designed to seamlessly integrate with other host platforms, KEB’s MFI gives customers ultimate design and control flexibility.
KEB America
www.kebamerica.com
Filed Under: I/O modules, IoT • IIoT • internet of things • Industry 4.0, Motors • stepper
Tagged With: kebamerica
RF 2.0 helps engineers with radio frequency and antenna design projects
Joint consortium standardizes common “Power Consumption Management” for the shop floor
Advantech, Hivecell partnership accelerates Edge-as-a-Service for scalable AIoT
IIoT platform captures data from nearly any legacy machine to simplify the move to Industry 4.0
