    • Subscribe!
EtherCAT Technology Group offering vendor-independent diagnosis interface
By Paul Heney | December 7, 2018
EtherCAT diagnostic data
The new ETG diagnosis interface enables master-independent access to EtherCAT diagnostic data.
The EtherCAT Technology Group (ETG) has specified a new vendor-independent diagnosis interface, which allows third-party tools to access diagnostic information from EtherCAT networks. The software-based interface can be implemented in controllers offered by any device manufacturer, which makes it an interesting feature to vendors of both master devices and diagnostic tools.
Diagnosis is one of the most important functions of a modern fieldbus system. EtherCAT provides extensive diagnostic information both at the hardware and software levels. An outstanding EtherCAT feature is the ability to not only detect errors but also to precisely locate them. This includes bit errors as well as issues generated by loose connectors. The corresponding error counters are supported by all network slave devices. This helps users, machine builders and system integrators ensure the robustness of EtherCAT networks and, as a result, reduce machine downtime to the absolute minimum. Furthermore, diagnostic routines test the quality of the communication and help easily detect internal errors in slaves, wrong cabling order, damaged cables or EMC interference.
ETG has specified this user-friendly, vendor-independent diagnosis interface so that third-party diagnostic tools can work with any master implementation. No hardware changes are necessary, since an EtherCAT master is software-based, as is the interface. The interface is easy to implement with a small software footprint, so it is even suitable for embedded devices with limited memory.
The standardized interface allows access to EtherCAT network diagnostic information for both hardware and software. Through the information provided by this new interface, diagnostic tools or HMIs can retrieve the EtherCAT network topology information, compare it with the expected configuration and detect communication interruptions and disturbances, as well as unexpected state changes.
The specification ETG.1510 “Profile for Master Diagnosis Interface” enhances the “EtherCAT Master Classes” specification and extends the EtherCAT Master Object Dictionary already defined in the “Modular Device Profile” specification. Likewise, the access mechanism makes use of the already specified Mailbox Gateway functionality. Based on existing standards, the new profile is easy and straightforward to implement.
Filed Under: ALL INDUSTRY NEWS • PROFILES • COMMENTARIES, Networks • connectivity • fieldbuses
Paul Heney
Paul J. Heney, the VP, Editorial Director for Design World magazine, has a BS in Engineering Science & Mechanics and minors in Technical Communications and Biomedical Engineering from Georgia Tech. He has written about fluid power, aerospace, robotics, medical, green engineering, and general manufacturing topics for nearly 25 years. He has won numerous regional and national awards for his writing from the American Society of Business Publication Editors.
MTConnect Institute releases Version 2.0 of the MTConnect Standard
OPC UA
Everything is moving – OPC UA Companion Specification “Global Positioning”
Single common conformance test plan to be available for the IEC/IEEE 60802 TSN profile for industrial automation
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
    • Subscribe!
