The C6 Router, when partnered with COMBIVIS Connect software, provides everything needed to connect remotely to machines in the field for commissioning, program adjustment and troubleshooting using KEB’s secure VPN connection to networked servers around the world.
The Ethernet-based C6 Router comes with WAN, LAN, USB and serial interfaces, and standard digital I/Os. For hard-to-access installations, like wastewater treatment facilities, oil and gas, and wind turbines, a cellular network option is available. These models include standard 2G/3G/3G+ EDGE/HSPA quadriband capable of speeds of up to 5 Mbps up/14 Mbps down. They come with one push-pin type SIM card and SMAStecker antenna, with the option of adding an auxiliary Diversity antenna.
In addition, the C6 Router handles harsh environments. The unit is housed in a stainless-steel enclosure and is ready for DIN rail or wall mount. There are no fans or moving parts to maintain and an extended temperature option is available for extreme environments (-20 to 70° C).
Filed Under: TECHNOLOGIES + PRODUCTS, Ethernet — cables • hubs • switches, I/O modules, Software
