Ethernet Drive Module and Serial Communications Module from AutomationDirect
By Design World Staff | May 25, 2011
AutomationDirect’s new GS-EDRV100 Ethernet drive module provides a high-performance Ethernet link between a control system and any GS or DURApulse AC drive. The module processes signals to and from the drive, mounts on 35mm DIN rail, and connects the drive to an Ethernet hub or PC. It formats drive signals to conform with the Ethernet standard and transmits these signals to the H2-ERM or H4-ERM, Productivity3000, KEPDirect OPC Server, KEPDirect EBC I/O Server, or independent controllers with a Modbus TCP/IP driver. This allows for greater connectivity to many control system architectures. The GS-EDRV100 is equipped with a serial and an Ethernet communication port and LED activity indicators. The module ($185) features a built-in Web browser which allows users to configure and control the drive from any Web browser via the IP address of the GS-EDRV100 module.
AutomationDirect has also added the H2-SERIO-4 serial communications model to its line of communication devices for WinPLC and PC-based control systems. The H2-SERIO-4 module has two RS-232C ports and one RS-422/485 terminal. Each port on the module is capable of full hardware handshaking.
AutomationDirect-GS-EDRV100-Ethernet-drive-module
AutomationDirect
www.automationdirect.com
Filed Under: Factory automation, Automation components, Drives (ac) + VFDs + starters, Networks • connectivity • fieldbuses
Tagged With: automationdirect
Solid-state relay characteristics and applications
