Ethernet IP Remote I/O Solution
By Design World Staff | January 31, 2011
APAX-5072 is a high-density Ethernet IP communication coupler introduced by Advantech Industrial Automation Group. The APAX-5072 features ODVA (Open DeviceNet Vendors Association) authorization, allowing it to link with any Ethernet IP master to easily build a reliable Ethernet IP remote I/O solution.
APAX-5072
The APAX-5072 features two RJ-45 ports with the same IP address for building daisy chains, which allows users to connect remote I/O devices directly without an additional Ethernet switch. It also provides dynamic configuration that allows users to configure different channels with different types and ranges in one module. Moreover, leveraging the APAX features of high density I/O, flexibility, scalability, and hot swap functionality, the APAX-5072 is able to connect APAX digital I/O modules or analog I/O modules to build remote I/O systems for fulfilling PLC or control application needs.
The APAX-5072 coupler has large connecting capacity and able to connect with any Ethernet IP master, such ABB PLC, effectively allowing users to build cost-effective Ethernet IP remote I/O systems.
Advantech Corporation
www.advantech.com/ea
Filed Under: Factory automation, I/O modules, Networks • connectivity • fieldbuses
Dual high-temperature Cabinet Cooler systems for large enclosures
