ETHERNET 2.0 (IP20) and SPEEDWAY (IP67) Ethernet Starter Kits offer a low-cost approach to training. Developed to provide the Wago-I/O-SYSTEM fundamentals, the kits consist of comprehensive I/O nodes complete with software site licenses and hardware. The kits also include free, downloadable sample applications including: visualization, controlling process digital inputs and outputs, controlling rotating machinery and processing the fieldbus controller’s real-time clock.
The IP20 Ethernet Starter Kit contains: 750-880 Ethernet 2.0 PLC with SD Card, a 2-channel DI and DO modules, power supply, 2-way digital input simulator and end module. The 750-880 blends IT-style flexibility and PLC functions, demonstrating large-scale programming, data logging, backup/restore and more via SD Card.
The IP67 Starter Kit introduces cabinet-free automation through prominent protocols such as Modbus/TCP and EtherNet I/P. It features a SPEEDWAY programmable controller with Ethernet ports, 8-channel DO and spacer modules, power supply rocker switch and
RJ-45 to cable breakout module.
WAGO
www.wago.us
Filed Under: CONNECTIVITY • fieldbuses • networks • gateways, ENGINEERING SOFTWARE, Power supplies, MOTION CONTROL, PLCs + PACs
