Ethernet Switch Includes Alarm Output
By Design World Staff | September 11, 2009
The 852 Series Ethernet switches offer an alarm contact that is enabled through a dipswitch to signal an error condition on the switch.  This feature is standard on both managed and unmanaged switches (non-ECO versions).
The power input connector on the switch has two dedicated alarm circuit connections that can be wired to any warning device, such as a PLC or pilot light.  Error conditions that can be monitored include port link failure (cable disconnect, network disruption, etc.), power supply disruption/disconnect, or power supply voltage out of specified range (9 to 48 V).
WAGO
www.wago.us
Filed Under: Ethernet — cables • hubs • switches, Networks • connectivity • fieldbuses
Ethernet/IP Network specification complete for Ethernet-Apl physical layer for process automation
Avnu Alliance launches global TSN Certification program
Hardened multi-speed mega PoE injector for diverse infrastructure applications
EKI-7000 Series Firmware Revision makes network management more secure
