The EDS-305-M12 series of 5-port industrial unmanaged Ethernet switches
with M12 connectors are for the toughest industrial applications. The rugged,
IP67-rated design makes these switches suitable for use in outdoor environments,
such as the transportation, mining, and water and wastewater treatment industries.
The switches are water-resistance, as well as resistant to the effects of dust, dirt,
humidity, vibration, and shock.
TheM12 connectors ensure a tight connection, and keep your Ethernet connections
from popping loose in high-vibration applications, such as in moving
vehicles. In addition, the switches have industrial and safety approvals, such as
UL508, Class 1, Div. 2, and will also
receive DNV/GL maritime certification
for specialized applications.
Two models are available, both IP67
rated. One model has an operating temperature
range of 0 to 60oC; the other
has a range of -40 to 75oC. Other
features include: 5 10/100BaseT(X)
M12 connectors; 10/100M, F/H duplex
mode, and auto MDI/MDI-X connection;
and power input at 12 to 45 VDC,
18 to 30 VAC.
MOXA
www.moxa.com
:: Design World ::
Filed Under: Off highway • construction, Ethernet — cables • hubs • switches
