    • Subscribe!
ETHERNET/IP™ Gateways
By Design World Staff | November 15, 2007
EtherNet/IP piconet® gateways are available with either eight M8 picofast® or four M12 eurofast® connectors, and they provide four points of digital I/O. The piconet gateway has two fiber-optic connectors to add modules and increase the number of I/O points on a node. A new extension module provides an additional eight inputs and outputs, and the module’s terminal strips feature cage clamp technology for simple mounting inside a panel. Up to 255 extension modules may be connected to each gateway.
The IP-Link fiber-optic communication system now allows up to 15 meters between modules, which lets you encircle an entire machine with I/O using a single node on the network.
TURCK
www.turck.com
: Design World :
Filed Under: I/O modules
Beckhoff’s EPX series EtherCAT I/Os provide intrinsic safety in IP67 form factors
New economical linear modules for lighter loads
Ethernet remote I/O modules add Conditional Logic Computing
Io-link-Smartfield
IO-Link Smart Field I/O System from AutomationDirect
    • Subscribe!
