  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
      • EE World Digital Issues
    • 2020 LEAP Awards
    • Motion Design Guide Library
    • Suppliers
  • COVID-19
EXAIR Cold Gun coolant is effective alternative to mist
By Lisa Eitel | November 20, 2019
Heat build up on dry machining operations reduces tool life and machining rates. The Cold Gun Aircoolant System solves that problem and produces a stream of clean, cold air at 50°F (28°C) below supply air temperature. Operation is quiet and there are no moving parts to wear out. It will remove heat to prolong tool life and increase productivity on machining operations when liquid coolants cannot be used.
The Cold Gun is also an alternative to expensive mist systems. It eliminates the costs associated with the purchase and disposal of cutting fluids and worker related health problems from breathing airborne coolants or slipping on wet floors. EXAIR’s Cold Gun is non-adjustable to prevent freeze-up during use.
The EXAIR Cold Gun gives instant cold air when filtered compressed air is supplied to it. Cycling on and off is a good way to save air. The use of clean, filtered air is essential to the operation of the Cold Gun. A filter separator that removes moisture, dirt and other particulates from the compressed air is included with each Cold Gun System. EXAIR’s High Power Cold Gun Aircoolant System produces twice the airflow of the standard Cold Gun, doubling the cooling capability.
EXAIR is offering a special right now on Cold Guns. Learn more at www.exair.com/58/cgpromo.htm.
You may also like:
  • Anti-static Super Air Knife has 34% better performance and CE,…
  • EXAIR line vacs convey material with no moving parts
  • EXAIR no-drip atomizing nozzles conserve liquid
  • Soft Grip air scraper from EXAIR with extension pipe
  • New hose-based conveyor option from EXAIR for materials up to…
About Lisa Eitel
Lisa Eitel has worked in the motion industry since 2001. Her areas of focus include motors, drives, motion control, power transmission, linear motion, and sensing and feedback technologies. She has a B.S. in Mechanical Engineering and is an inductee of Tau Beta Pi engineering honor society; a member of the Society of Women Engineers; and a judge for the FIRST Robotics Buckeye Regionals. Besides her motioncontroltips.com contributions, she also leads the production of the quarterly motion issues of Design World.
MOTION DESIGN GUIDES
  • With virtual commissioning, commissioning time and prototype waste is reduced
  • Master Bond Supreme 10HT High Strength, NASA Low Outgassing Approved Epoxy
  • Drilling Rig OEM Benefits from a PLC with Edge Computing Technology: IIoT Case Study
  • #1 Reason for Retaining Ring Failure & How to Overcome It
  • Motion controllers: design from scratch or buy ready-made?
Tweets by @DesignWorld
  • Articles
  • 3D CAD Models
    • 2020 Winners
    • 2019 Winners
    • 2020 LEAP Awards
    • DIGITAL ISSUES
    • 2020 LEAP Awards
    • Suppliers
  • COVID-19
