EXAIR’s Gen4 Ion Air Jet delivers a concentrated airflow that can cover a precise spot without disturbing other areas. This quiet, focused airstream provides incredibly fast static decay rates and cleaning ability. The new and improved Gen4 Ion Air Jet is the suitable way to remove static and dust from small parts prior to shrink wrapping, packaging, printing, painting or finishing.
The Gen4 Ion Air Jet includes an armored high voltage cable to protect against abrasion, cuts, splits and other damage from the environment. It induces surrounding airflow at a ratio of 5:1, minimizing compressed air use and maximizing ionized airflow. Force can be adjusted from a blast to a breeze.
For permanent mount applications, the compact Gen4 Ion Air Jet is the best choice since it is lightweight and easy to install using the 1/8 NPT male inlet. For applications where frequent repositioning is required, the flexible Gen4 Stay Set Ion Air Jet is ideal. This version can be placed in close proximity and the hose bent to aim the ionized airstream at the localized area.
EXAIR is offering a special right now on all of their Gen4 Static Eliminators. For more information, visit exair.co/58-iajdirold.
You may also like:
Filed Under: TECHNOLOGIES + PRODUCTS, Automation components
