EXAIR offers a large selection of Line Vac conveyors that are ideal for moving large volumes of material over long distances. A small amount of compressed air is injected through directed nozzles to produce a vacuum on one end and high output flows on the other, with instantaneous response. The material flow rate is easily controlled with a pressure regulator. No moving parts or electricity assures maintenance free operation.
Our standard Line Vac comes in eleven sizes ranging from 3/8 inches to five inches so there is sure to be one in the size you need. But EXAIR didn’t stop there. There are also Threaded Line Vacs, Heavy Duty Line Vacs, Sanitary Flange Line Vacs and Light Duty Line Vacs. There is a Line Vac for all of your conveying applications. Each style comes in a number of materials and sizes.
Line Vacs have a large, smooth, straight bore that allows as much material to pass through as possible. Kits include a pressure regulator that is sized properly for flow. Contact EXAIR if you need help determining which Line Vac is perfect for your application. EXAIR is offering a special right now on all Line Vacs. For more information, visit this deep link at exair.com.
