EXAIR has introduced a cabinet cooling solution designed to help reduce electronic control system downtime caused by heat, dust, and moisture. The Cabinet Cooler uses a vortex tube to generate cold air from compressed air and has no moving parts.
This compact unit can be installed quickly through a standard electrical knockout or drilled hole. According to EXAIR, the cooler offers a cost-effective alternative to traditional Freon-based air conditioners or heat exchangers, requiring no ongoing maintenance.
Cabinet Cooler Systems are available in NEMA 12, 4, and 4X configurations, with cooling capacities up to 5,600 Btu/hr to suit a range of control panel sizes. All models are UL listed, UL classified, and/or CE compliant. Options include non-hazardous purge, high temperature, type 316 stainless steel, ATEX, and hazardous location versions. The systems are backed by a five-year warranty.
For more information, visit exair.com.
Filed Under: Cabinets • enclosures • control panels • DIN rail
