EXAIR’s 3 NPT heavy-duty threaded line vac
By Mike Santora | October 29, 2021
3 NPT Heavy Duty Threaded Line Vac™ Conveys Plastic Cap Nails.EXAIR’s new 3 NPT Heavy Duty Threaded Line Vac is a powerful in-line conveyor that transports high volumes of material through ordinary pipe. Designed for rugged, industrial applications, it is made of a hardened alloy to prevent premature wear when transporting abrasive or heavy materials like garnet, glass, sand, shot blast, tumbling media, or metal fittings. These units feature large throat diameters that make it possible to convey more material over long vertical and horizontal lengths. The conveying rate is typically twice that of ordinary air-powered conveyors.
Heavy-duty Threaded Line Vac Conveyors eject a small amount of compressed air through directed nozzles to produce a vacuum on one end and high output flows on the other with instantaneous response. Utilizing a pressure regulator, conveyance rate can be finely tuned to suit the needs of your application. There are no moving parts to wear out and no electricity is required.
Seven sizes from 3/4 NPT to 3 NPT fit standard pipe and coupling sizes. Additional models made from aluminum, 303SS, and 316SS are also available in eleven sizes, with or without threads. Sanitary flange models from 1-1/2 to 3-in. are also available. All EXAIR Line Vacs are CE compliant, meet OSHA pressure requirements, and are ready to ship from stock.
EXAIR
https://exair.co/58-3hdtlv
Filed Under: Product Design & Development
Tagged With: exair
2022-347-348_AS_10K3
Corrosion protection for oil and gas equipment from General Magnaplate
Honeywell announces Spring 2022 release of new offerings to Honeywell Forge
unnamed-33
igus introduces new geometries and new materials to its FastLine service
EXAIR’s CE Compliant Chip Vac
