Quiet, efficient, concentrated flow of ionized air removes static and dust. EXAIR’s Gen4 Ion Air Cannon neutralizes static electricity and cleans at distances up to 15-ft (4.6m) with no moving parts. It is suitable for those hard to reach spaces or confined areas that require a concentrated flow of static eliminating ions.
The Gen4 Ion Air Cannon will maximize ionized airflow while minimizing compressed air consumption. A small amount of compressed air is used to entrain a high volume flow of surrounding air. This combined stream is ionized by an emitter point (shockless) and delivered to the charged surface. A hose or tube can be connected to the air intake of the Gen4 Ion Air Cannon to draw quality air from another area. It requires only 10 PSIG (0.7 BAR) for most applications.
The Gen4 Ion Air Cannon produces maximum airflow at minimum air consumption.The compact design saves bench space and allows mounting in confined areas. The sturdy stand is pre-drilled and can be wall, bench or machine mounted. It incorporates a swivel adjustment for directing the airflow. www.exair.com/58/iacdirem.htm
EXAIR
www.exair.com/58/sepromo.htm
