Exlar’s Tritex™ II Series Electric Actuators
By Miles Budimir | July 1, 2009
Chanhassen, MN – Exlar announces the Tritex™ II Series electric actuators are now available with a cost-effective absolute feedback option. The compact actuators feature a built-in mechanical converter, eliminating the need for a ball screw or gear reducer mechanism. With the absolute feedback option, Tritex II actuators eliminate the need to perform home cycling–without the high cost and inconvenience of alternative solutions.
Tritex II Linear Actuator with Absolute Feedback Option
To offer proper control and travel within the physical limits of the system, actuator application systems must first identify the position of the actuator upon initialization. This is commonly achieved by a time-consuming and inconvenient homing routine that requires the system to travel on a power up setting until a switch is reached or through a hard stop that establishes the home, or zero position. Alternatively, costly feedback devices such as cumbersome linear transducers or less-reliable multi-turn serial absolute encoders are used.
Tritex II Rotary Actuator with Absolute Feedback Option
The user receives absolute feedback information from the Tritex II without performing home cycling. This option card costs less than a standard incremental encoder and far less than a serial multi-turn absolute encoder. The robust Tritex II provides this absolute feedback while retaining the operational and environmental capabilities of the actuator. The user isn't forced to compromise actuator performance, as is the case with some absolute feedback devices.
Tritex II actuators provide 1500 Watt, AC powered operation and digital position control, pairing a brushless servomotor with rotary or linear actuation. By including all required position control and power electronics into the self-contained, sealed actuator, Tritex II delivers a comprehensive system solution that stands up in even the most demanding environments.
Exlar Corporation
www.exlar.com
Filed Under: Actuators, Motion control • motor controls
Miles Budimir
