New expansion I/O modules from AutomationDirect for the BRX stackable micro brick PLC include communications modules, universal analog I/O modules, and universal temperature combination I/O modules. Expansion modules snap onto the side of any BRX Micro PLC Unit (MPU) or BRX Remote I/O controller, creating a sturdy and rugged PLC platform.
Added BRX serial communications modules ($159.00) provide four isolated RS-232 ports that support communications flow control or RS-422 serial ports. Also available are BRX single-channel RS-232 (with flow control) and RS-422 Pluggable Option Modules ($49.00). Supported protocols include Do-more! Protocol, Modbus RTU (Master/Slave), K-Sequence, and ASCII (In/Out). Data rates are 1200 to 115,200 bps.
Universal analog I/O modules (from $159.00) have combined current and voltage options. Universal temperature modules provide thermocouple, mV level voltage, RTD or thermistor selection with 24-bit resolution. The 4-channel combination temperature I/O expansion module ($349.00) has universal temperature inputs and analog outputs. Four-channel combination temperature input / discrete output modules ($199) provide universal temperature inputs and discrete sink, source or relay outputs.
The AutomationDirect BRX PLC system is engineered, manufactured and supported in the U.S. and backed by a 2-year warranty.
AutomationDirect
www.automationdirect.com/brx-plcs
Filed Under: IoT • IIoT • Internet of things • Industry 4.0
