    • Subscribe!
Expanded communications and discrete I/O capabilities for the BRX PLC
By PR Editor | December 10, 2020
Expansion modules snap onto the side of any BRX Micro PLC Unit (MPU) or BRX Remote I/O controller.
Newly added BRX discrete I/O modules include 5, 8, and 16-point relay output modules (starting at $55) with Form A (SPST) and Form C (SPDT) options; 16-point 2-5 VDC discrete input and output modules (starting at $55); a 16-point 2-5 VDC discrete combination input/output module; and the HSIO4 high-speed pulse combo module ($219) capable of handling up to a 2MHz frequency in differential or single-ended wiring configurations.
In addition, a new Pluggable Option Module (POM) with full Ethernet capability and support for MQTT Client, Do-more, EtherNet/IP, Ethernet remote I/O, and Modbus TCP protocols (for use with Ethernet MPUs only) ($79) has also been added to the lineup.
AutomationDirect
www.automationdirect.com/brx-plcs
Filed Under: IoT • IIoT • internet of things • Industry 4.0
Tagged With: automationdirect
Softing introduces OPC UA-based OT/IT integration solution with MQTT connection
RF 2.0 helps engineers with radio frequency and antenna design projects
Joint consortium standardizes common “Power Consumption Management” for the shop floor
Advantech, Hivecell partnership accelerates Edge-as-a-Service for scalable AIoT
    • Subscribe!
