The Epljh-70led-1224I-100, low-voltage, scaffold, mount LED work light, is designed to provide low voltage operation with an inline waterproof transformer that converts standard 120 Vac current to 12 Vdc, and versatile mounting capabilities for workers in hazardous locations who commonly use ladders and scaffolds. The light is equipped with an adjustable scaffold mounting bracket and low voltage transformer, making it ideal for operators engaged in plant turnarounds, coal processing, petroleum refinement and other operations involving hazardous flammable materials.
The light fixture provides power and durability combined with the versatility of an adjustable J-hook ladder mount bracket that may be adjusted from 26 to 34 in. allowing operators to attach the unit to scaffolds and ladders of various sizes. At 70 watts, the light produces over 6,000 lumens of clean white light in a wide flood pattern and is well suited for illuminating larger work areas. The assembly is contained within an explosion proof aluminum housing with a ¾ in. thick thermal shock and impact resistant tempered glass lens, and housed in a rugged thermoset powder coat finish for resistance to abrasion and corrosion. In this unit are high quality CREE XLamp MC-E® and provide a 50,000 hour rated lamp life.
Having an adjustable center post allows operators to raise the lamp 3 feet, with the option of moving the lamp head either vertically or side-to-side for optimum coverage of the workspace. Included with the light is 100 ft of chemical and abrasion resistant cord ending in a 1523 explosion proof plug for safe and secure connections. This unit is approved for hazardous locations and carries Class 1 Division 1, Groups C and D, Class 1 Division 2, Group C, D certification and a T4 temperature rating. The light is also UL 781 portable Haz-Loc use certified as well as UL 595 certified for marine locations.
Larson Electronics
Magnalight.com
Filed Under: Power Electronic Tips
