Extended 5-port PoE+ gigabit unmanaged switch line
By Frank Tobe | March 11, 2016
The LNP-0500G and LNP-0500G-24 series unmanaged switch line expands the low port count gigabit connectivity product line for industrial applications. The LNP-0500G Ethernet switch is rugged and reliable and suits applications involving surveillance systems, data centers, research labs or any location that requires simple gigabit speed network expansion.
The low-voltage input and ability to provide high-power PoE allows the LNP-0500G-24 to fulfill transportation, factory automation vision inspection, solar and remote location surveillance applications.
These 5-port industrial PoE+ gigabit unmanaged Ethernet switches have a 48-to-55-Vdc high voltage power input (LNP-0500G) and a 12-to-36-Vdc low voltage power input (LNP-0500G-24). Each gigabit Ethernet port is IEEE 802.3at compliant (PoE+) on ports 1 to 4 (data and power output maximum 30 W/port) and backward compatible with IEEE 802.3af. The series supports MDI/MDI-X functions and a 10-KB jumbo frame.
AntairaThis product series provides high EFT, surge (2,000 Vdc), and ESD (6,000 Vdc) protection to prevent any unregulated voltage and can support the power redundancy feature using a dual power input design with reverse polarity protection. There is also a built-in relay warning function to alert maintainers when power failures occur.
Antaira Technologies
www.antaira.com
Filed Under: Power supplies
Tagged With: antaira
Wago-pro2-power-supplies
WAGO Pro2 Power Supplies and DC-to-DC converters from AutomationDirect
Traco Power launches new AC/DC power supplies
ECO 2 power supplies balance size, efficiency with tool-free installation
AutomationDirect-Power-Supply
RHINO power supplies with integrated UPS and Power Boost Technology
