Rather than connect external displacement sensing systems to a data acquisition module to capture the sensor’s signal, users of National Instruments CompactRIO platform can now use a fully compliant module for measurement ranges up to 15 mm. Previously, the range for Lion Precision’s eddy-current displacement sensor was 3.5 mm. The ECD140 Eddy-Current Displacement Sensors extend the range over four times with a maximum range of 15 mm. The only noncontact displacement sensor module available for directly plugging into CompactRIO system eliminates extra connector and cabling than can add problems to the measurement system.
For more information about the Lion Precision ECD140 Eddy-Current Displacement Sensors, click here.
Filed Under: Sensor Tips
