TWINSBURG, OH — Pepperl+Fuchs introduces X-Series Pile Driver™ Extended Range Inductive Sensors. These robust sensors are available in 12mm, 18mm and 30mm diameters to deliver sensing ranges of 5mm, 10mm or 15mm — up to 2.5 times longer range than traditional inductive sensors. 100% stainless steel housings deliver durability more than 20 times that of the competition’s brass and plastic housings. Black Armor™ coated weld-immune models are also available.
X-Series Pile Driver’s extended sensing field is a big benefit in automotive manufacturing applications, as it enables reliable detection of irregularly shaped contours, and increased sensor-to-target distances help eliminate contact-related scuffing of “Class A” hood, door and trunk surfaces. Weld-immune models are uniquely capable of providing long range part detection with full immunity to both AC and DC weld fields, and repelling weld splatter.
X-Series Pile Driver’s can detect all metals. Advanced circuitry enables restriction-free mounting while delivering the highest available immunity to the effects of industrial noise and temperature extremes. Unlike traditional inductive sensors that are limited to IP67/68 protection, X-Series Pile Driver sensors are IP69k-rated to withstand high pressure washdown cleaning.
Pepperl+Fuchs
www.pepperl-fuchs.com
Filed Under: Automotive, Sensors (proximity), Test + measurement • test equipment
