The new EL6688 EtherCAT‚® Terminal permits precise cross-factory and cross-site synchronization according to the IEEE 1588 standard. Using the EL6688, different machines, system components or production lines can be accurately synchronized with each other or with an external grandmaster clock via GPS or DCF77 receivers.
With the distributed clocks, all devices in an EtherCAT system can be synchronized with a tolerance of less than 100 ns. The terminal permits synchronization with different networks across sites.
The EL6688 EtherCAT Terminal supports the Ethernet-based IEEE 1588 protocols PTPv1 (IEEE 1588-2002) and PTPv2 (IEEE 1588-2008).
The EL6688 is an IEEE 1588 clock (ordinary clock), which, from the perspective of the higher-level master (grandmaster), operates as a slave or supplies the connected EtherCAT Terminals (slaves) as a master via distributed clocks. The EL6688 terminal can be located at any point within an EtherCAT Terminal network.
Beckhoff Automation‚®
www.beckhoffautomation.com
Filed Under: Ethernet — cables • hubs • switches, Networks • connectivity • fieldbuses
