Extruded aluminum enclosures feature wall mounting
By atesmeh | June 25, 2012
TEKO Enclosure Solutions have extended the TEKAL series of extruded aluminum enclosures with models which can be easily mounted to a wall, control panel, machine housing or bulkhead. The new TEKAL-E wall mount enclosures feature end panels with integrated mounting flanges. These are designed to allow the unit to be mounted without the need to open the enclosure or disturb electronics. The case section features internal guide rails for mounting slide-in PCBs, and recessed areas on the top and bottom can be used for mounting membrane keypads or product labels. The end panels are also recessed for keypads or to protect the connectors and switches.
tekoenclosures.com
