Extruded Plastic Sheet in Pre-Cut Strips
By atesmeh | April 9, 2013
[[{“fid”:”246777″,”view_mode”:”full”,”type”:”media”,”attributes”:{“height”:300,”width”:225,”style”:”float: right; margin: 10px;”,”class”:”media-element file-full”}}]]Ensinger/Penn Fibre has developed a way to deliver any material they extrude in pre-cut strips of various thickness and width. This method of pre-cutting to get a sheet into strip form as is often needed in the first step to a stamping or machining operation has proven to be very inexpensive if more than 50 to 100 sheets are needed for the job. Capabilities include:
  • The ability to handle any Ensinger/Penn Fibre extruded material up to .156 thick and 2 feet wide.
  • A modified slitter for strips that are slit from standard 2 x 4 foot sheets.
  • The availability of factory quotations.
For more information visit www.pennfibre.com.
