FactoryMation introduces new relay series from Finder
By Stacy Combest | June 25, 2013
FactoryMation expands its product offering from Finder to now include the newly introduced 39 Series Terminal Block Relays. This new series of terminal block relays provides cost and space savings while incorporating advanced features for many industrial applications.
The Finder 39 Series terminal block relays
The Finder 39 Series terminal block relays provide an ultra-slim 6.2mm wide package and 35mm DIN rail mounting clip for ease of installation with minimal consumption of space. Relays are available as electromechanical or solid state and are easily ejected and replaced with the use of an integrated retaining clip. The Finder 39 Series terminal block relays offer a transient voltage coil suppression circuit. An innovative, replaceable fuse module is optional to provide output circuit protection. Fuse modules accept 5x20mm glass fuses up to 6A, 250V. Connections for a 16 way jumper link, dual screw head terminals and optional jumpers reduce wiring time resulting in increased efficiency. All units come with an IP20 protection rating. Priced from $16.
FactoryMation
www.factorymation.com
Filed Under: Relays, Terminal blocks, ELECTRONICS • ELECTRICAL
Tagged With: factorymation
